Re: Z Spar
Posted by Veto on Sep 11, 2005
Howard: CLC states in the manual that if you have a HVLP sprayer that is the way to go if you know how to use it. I don't spray finishes for a living but I am knowledgeable w/ experience. And I can assure you that spraying is considerablly quicker than brushing. That said, if the spray job is inadequate brushing could be the better method for sure!
In Response to: Re: Z Spar by Howard on Sep 11, 2005
