Re: Nails & deck attachme
Posted by Howard on Sep 7, 2005
no pilot holes necessary...the plywood won't split. both karl and kurt are pretty much right...while they won't split, you need to ensure you have a good system for bending the wood and that system really needs to allow you to keep your hands free in order to drive the nail cleanly.
half my boats i have built using nails, the other half with nailess construction....which is an approach you can consider if you are not excited about the nailed look.
hs
In Response to: Re: Nails & deck attachme by Brad on Sep 7, 2005
