Re: Question about epoxy
Posted by Howard on Sep 4, 2005
it should not be a problem, and as clc suggested, as a clear-coat, you will not see a colour difference.
but the placement of epoxy is a big effort and you are right to be concerned to make sure its going to go off right.
do a simple test batch in a cup (one pump of each). if it're fine. if it doesn't you have some more work to do.
In Response to: Question about epoxy by Kurt Freewald on Sep 4, 2005
