Fiberglassing Pram
Posted by Duncan on Jul 31, 2005
Why is is recommended to glass only the bottom panel of the Eastport Pram's exterior? I will be using mine as a full time working dinghy while liveaboard cruising, and was thinking I'd like to continue the glass up over the #1 strakes. I assume the only problem would be to make sure the glass can lay flat against the transition?
- Re: Fiberglassing Pram by Steve Miller on Jul 31, 2005
- Re: Fiberglassing Pram by CLC on Jul 31, 2005
- Re: Fiberglassing Pram by Duncan on Jul 31, 2005
