Re: Epoxy underside of de
Posted by LeeG on Jul 28, 2005
one of the problems I found with one slathering coat is that sometimes the grain can feather up and when it cures you've got a 100grit surface, great for gluing minicell not exactly knuckle friendly. Likewise if you put on the deck with a wet underside and had some reason for turning the deck over,,all that stuff that didn't get vacuumed out was glued to the underside of the deck. Of course if you don't turn the kayak over when the underside is wet it isn't a problem.
In Response to: Re: Epoxy underside of de by Dave Houser on Jul 28, 2005
