accurate use of words
Posted by LeeG on Jun 1, 2005
Once slow cure epoxy is called a no-blush epoxy it didn't change the consequences of using epoxy in high humidity environments. Of course the product brochure mentions the parameters of its use but the focus on one aspect by name, no-blush, of an epoxies characteristics when viscosity, temp, surface characteristics are equally significant allows for the above problems to develop more readily for the beginner when he's buying "no blush" epoxy instead of "slow cure" epoxy.
In Response to: Let's be careful.... by CLC on May 31, 2005
