Re: Prepping exterior of
Posted by Howard on May 30, 2005
i would go with one of the sanders...whichever you are more comfortable with.
it wont take long to get rid of 1/8 of an inch. use a straight edge to mark a straight line...and use the straight edge to check your work.
the bow and stern also get rounded/radiused...so that the cloth falls over it neatly....you can do this at you are shaving the bow and stern.
the forward deck beam is the same radius as the main deck beam. 16 inch sounds correct but it should be on your plans.
hs
In Response to: Prepping exterior of hull by Alan Nolan on May 30, 2005
