Re: Epoxy problems
Posted by Scot on Apr 15, 2005
In addition to the lacquer thinner suggestion, I've always had great results wet sanding with 220. Sometimes contamination can get smeared around with the solvent rag if it's not turned frequently. I use a bucket of warm water with about two drops of dish soap in it. I sand the whole hull with a soft foam rubber block (auto parts store) and good quality wet sanding paper. When done I rinse it again with fresh water, and let it dry in the sun. Well, it is southern California after all.
In Response to: Re: Epoxy problems by CLC on Apr 15, 2005
