Re: white spots from pull
Posted by Howard on Mar 28, 2005
i have experienced this when you use a hot iron to pull out copper wire. no way to avoid it if you pull the wires out after having epoxied them in.
don't worry about it. when you epoxy the inside of the hull and the outside, the epoxy should fill in these holes. its not a problem.
In Response to: Re: white spots from pull by Peter on Mar 28, 2005
