Re: Deck Glass/Hull overl
Posted by George K on Mar 25, 2005
I run 2" masking tape around the entire boat 1.5" down. Let the cloth overlap that (about an inch) and wet it out with a roller. When the epoxy has set for a while trim just above the tape with a new blade in the razor knife. The excess wet cloth will come off clean, no fraying. Pull the tape right away. Only takes a couple of rolled on fill coats and a bit of sanding to fair this into the side panels. All my boats are bright finish. You won't be able to see the trim line.
George K
In Response to: Deck Glass/Hull overlap by Shuswap Pat on Mar 25, 2005
