Re: fast epoxy
Posted by terry on Mar 10, 2005
I agree with John, with reasonable temps, overnight should cure a joint enough to be handled without having to resort to fast cure hardener. Scarfs in particular are nice long joints with lots of adhesion surface area.
If the temps are a bit low overnight, I shine one of those cheap, 500 watt halogen lamps on the joint. Works great, but runs up the elec. bill. A poke with a screw driver on the epoxy near the joint is a final test.
In Response to: Re: fast epoxy by CLC on Mar 9, 2005
