Re: epoxy coats
Posted by Steve Miller on Nov 18, 2004
Runs and drips mean its being applied too thick. Use a roller and put thin coats on. It will cover after enough coats.
If you have let more than about 24 hours go by between coats you might have some blush there so wash well with warm water and sand a bit. Then try coating again.
All this assumes the goo is kicking off right and setting hard.
In Response to: Re: epoxy coats by Mark Camp on Nov 18, 2004
Fall Kit Sale 2016
