Re: stress crack
Posted by Terry Mcadams on Sep 9, 2004
Sounds fine. But I'm curious: is the crack so bad that the decking is displaced along it? If so, you may want to do a more thorough repair. If not, Chris's advice makes perfect sense. A good winter project. And if you use 4 oz. glass, it will blend in with the unglassed section a little better.
terry
In Response to: Re: stress crack by Andy Szymczak on Sep 9, 2004
