Re: a few questions
Posted by C. fronzek on Aug 13, 2004
Michael, The more information you give the more you get. What Brand of epoxy? What's the mixing ratio? How long ago was the epoxy applied? How much of the boat is glued with this stuff? From the small amount of info you've supplied I'd say stop where you are and figure out what's wrong. If you can be certain that the epoxy will harden if mixed properly then use it. If in doubt get something else. Epoxy that stays soft has to come off. Sorry! Charlie
In Response to: a few questions by Michael on Aug 13, 2004
