Re: Epoxy in the wire hol
Posted by Chris on May 13, 2004
Are you painting or varnishing. If you're not real neat with the fill in on the holes, you might stain the wood around the hole, which will show more than the hole. Might be better to fill them in with unthickened epoxy, cause it's clear. I didn't bother, and you can barely see the stiching wires and holes. glass and epoxy sealed it fine. Actually, I use them to explain the construction of the boat, and kind of like them.
cj
In Response to: Epoxy in the wire holes? by Dave on May 13, 2004
