Re: Hatch camber
Posted by gert walter on May 4, 2004
Joe: one more thing to add to the above. The more camber there is, of course the more force there is to separate the ribs from the hatch. I found it helped to get the exact curve by cutting through the first ply of the hatch okoume, cutting parallel lines on the underside with a pull saw - the entire length of the hatch, about 1" apart (before applying the rib of course!). Then there is much less springback and force trying to separate the pieces. gwalter
In Response to: Re: stitching wire by mike on May 4, 2004
