Re: Slow leak
Posted by RogerJ on May 3, 2004
Ice Phil, your idea sounds reasonable to me, of no experience. I do admit the first thing that crossed my mind was water coming out the top of the tube. Even above the waterline the odd wake from a passing boat or a bit of chop could peak above the top of the tube. You ran your test and that does sound like the leak is down low. A dam and pour at the base of the tube should strengthen that area tho'... Let us know what works. RogerJ
In Response to: Re: Slow leak by Ice-Phil on May 3, 2004
