After a medical hiatus I have returned to continue with my PMD build. I find that the daggerboard trunk is not fitting flush against either the vertical or botttom surface of the center bulkhead. At one point the fit was too tight so I obviously over-corrected. There is perhaps up to an 1/8 in clearance on both surfaces. Can I simply fill in with thickened epoxy? I have thought about trying to use shims but wasnt able to fit anythig in .that made sense, Suggestions are appreciated. I would attach photos but have uneven success doing so. Bruce
