How to repair deep scratches on wood duck?
I finished my wood duck hybrid this spring and due to the assistance of this forum it actually turned out ok. I bought a kayak rack that is on the wall of my garage and managed to put several gouges in the hull down to the fiberglass. The fiberglass is visible but I cannot feel the texture. Here is where it gets ugly. I had as small amount of varnish left so I thought I should just touch it up with varnish and it would make the gouges dissappear. Bad idea. I then read on pygmie boats site that I should have sanded it down to the (now varanished deep scratches) and apply epoxy then varnish.. OOPS. I tried just some hand sanding , applied epoxy, and the fiberglass did not dissappear. Maybe the varnish prevents that?? Sand deeper?
So my varnish has hardened, I cannot be certain of where the epoxy went since the scratches are not just a simple staight line and I realize I should just revarnish the hull. I ordered 1 pint of varnish. I will do an orbital sand of the hull to clean it up but.... how do I get the gouges and fiberglass weave to dissappear if possible? I will sand down on these areas and apply thin layer of epoxy then varnish or am I missing something. Keeping in mind the scratches are not visible when the kayak is in the water. thanks
1 reply:
RE: How to repair deep scratches on wood duck?
» Submitted by Laszlo - Sun, 8/14/22 » 5:20 PM
Sand down to bare wood on the damaged areas to remove the damaged glass and apply a glass patch.
If the damaged areas are small enough, you can just paint them with epoxy after sanding and not bother with the patch.
