Oxford Shell II finished dimensions
Greetings! First post.
I have always wanted a sliding seat rowing shell, and I am almost about to pull the trigger on an Oxford Shell II kit. The only place I can build it, however, is my climate-controlled basement, which means it would need to pass though a 20" by 50" window. I found the finished length and width dimensions, but cannot find the height anywhere.
Can anyone provide the finished height dimensions from bottom of hull (keel, I guess?) to top of deck (coaming?) at thickest part? If it is too thick it could be a dealbreaker.
Thanks much,
RE: Oxford Shell II finished dimensions
Thank you George K! I did not scroll down far enough to see it and completely missed it. Shows how much attention to detail I lack.
Thanks much,
» Submitted by George K - Sat, 10/2/21 » 7:45 AM
Go to the Oxford II page and scroll clear to the bottom, there's a guide to what size hole you'll need to get it out of the basement. You'll find your window is plenty big!
George K
