Sanding scratches seen through second coat of varnish
Ok ! Ch 17 has turned out great so far for my first build! Now I'm in the process of varnishing and on my second coat I can see some very slight sanding marks from the wet sand under the second coat ! Should I just move on or should I try to correct it ? Maybe give a light sanding with 400 on the orbital. Just curious what any of you guys would do. Thanks for your input! 😁
1 reply:
RE: Sanding scratches seen through second coat of varnish
» Submitted by wookmaster - Fri, 7/23/21 » 11:05 AM
Its scratches from sanding the first coat? Or scratches from sanding the epoxy? Are you wet sanding? Keep the sandpaper cleaned off with water. I'm using 300+ grit to wet sand and havn't seen this issue. Just clean the sand paper often, dip in a bucket of water or something so the stuff sanded off doesnt goop up on the sandpaper.
