Sanding and bottom edges on kaholo
�So this is my first wood working project. The book doesn't quite explain how far to sand the hull edges or chines if I'm supposed to see a little of the fillets or rounded enough and fill in the channel between the two edges of plywood (so far I don't see any gaps. ). Thanks for any advise!
RE: Sanding and bottom edges on kaholo
��that's what I would think. Just enough to where the FG can be smoothed over the edge
» Submitted by Marton - Mon, 8/1/16 » 10:51 AM
I just checked out the construction photos of a kaholo and was pretty surprised at the complexity. Not just a board you stand on at all. If I understand your question,the edges should be rounded to give a nice smooth curve. If you get to the fillet underneath, youve gone too far.
