I have started to build my new Passagemaker Dinghy and have discovered an annoying problem which I now call "epoxy creep". While spreading the epoxy on my planks and being ever so careful with drips off the edges I have discovered that it creeps under the plank regardless and creates another round of sanding. I now put some Short sticks under the planks and the problem goes away. Thanks, John
RE: Epoxy goofs
Can you explain this issue in a little more detail...and what you mean by using "short sticks" to deal with it...for one who is about at the same stage on another Passagemaker?
RE: Epoxy goofs
» Submitted by CaptainSkully - Tue, 5/31/16 » 9:10 PM
Ah, the power of "wicking", otherwise known as caplillary action. At least you found the solution. Now that PMDBuilders.net is kaput, I'd love a place to congregate, PMD-style. I'm about to start my take-apart.
