When I came to the point of installing the cleats supporting the thwarts in our NE Dory build I found it difficult to strike an accurate mark on the hill that would assure a dead on seating of the thwart. Came up with a process in which I package taped the ends of the thwart to prevent sticking of epoxy. Then pressed the cleat firmly up under the thwart, marked a line under the cleat, taped the line to better establish the right level then glued the cleat in place. After cleaning up and taping the cleat in place, I Layed in the taped thwart and firmly pressed the cleats in place. Now the cleats are firmly in the exact place they need to be. Much easier done than said!
https://www.icloud.com/sharedalbum/#B02GdPblXGckn2V;B70A74D6-5BE4-47D9-ABF1-4B5E8E05909E
1 reply:
RE: NE Dory thwart cleats
» Submitted by Jim R - Tue, 5/31/16 » 7:05 AM
