For the Mill Creek (or probably any other), what type of wood is used for the Row Wing Mounting Blocks? I can see the placement measurements in the Mill Creek 16.5 construction gallery, but I can't tell the thickness. Can I use exterior plywood and paint it to match the interior or do I need to use something higher quality? Is it two pieces of 1/2" or some other dimensions?
Thanks,
Scott
1 reply:
RE: Row Wing Mounting Blocks
» Submitted by smklein20 - Fri, 8/28/15 » 4:28 PM
Never mind. I found that the blocks I needed were in another box.
Scott
