Help With Rice Paper Graphic Ghosting On Chesapeake 17lt
First time boat builder, I have been working on two Chesapeake kayaks from plans for almost one year and am close to finishing them. Much apreciation for the wealth of information and inspiration on this forum.
I fiberglassed the deck of my 17lt this weekend and included two rice paper graphics underneath the fiberglass. The rice paper appeared to wet out perfectly, but in some lighting conditions becomes very noticeable. I followed the advice available on the forum for rice paper graphics.
Both images were black and white and printed on a B&W laser printer, one was printed regularly and one I printed reversed.
I did a sample image and practiced on scrap okoume and the paper blended much better than on my smoothly sanded deck.
I trimmed away as much of the excess paper as I could and used a clean plastic squeegee to wet out each graphic.
The plywood is 4mm okoume from Harbor Sales in Maryland, the fiberglass cloth is 4 oz. cloth from US Composites, and the Epoxy is MAS from CLC.
I can live with the images on my boat, but, would like to do a better job on my wife's 16lt.
Thanks,
Dave
7 replies:
RE: Help With Rice Paper Graphic Ghosting On Chesapeake 17lt
Looks a tad milky, but fine. I think both look good. I may give this a try
The ones on my WD12 went on perfectly and the paper was completely invisible, but after 7 1/2 years of sun, fun and weather changes it has turned into something like the first picture. So it may not be worth worrying about over the long run. The boat still floats just as well as it ever did.
Have fun,
Sort of a Good News/Bad News thing?
Good News: I'm doing it right
Bad News: I'm not going to get better results next time.
I guess in the grand scheme of things it's not so bad, in some lighting it's barely noticeable, and in complete darkness I can't see the difference at all.
Dave
where are some sources for the rice paper?
ddeaton,
I purchased mine from Amazon.com, there were a few options, but without knowing much about the different types of rice paper my choice was was more of a guess.
Dave
» Submitted by Patrick N - Tue, 8/4/15 » 1:39 PM
This might be as good as it gets. You're technique seems excellent.
I've fiddled with this quite a bit and my experience is that:
Interestingly, clarity seemed best to me at wetout. I think the visible weave of the fiberglass confused the eye a bit and distracted from the contrast. After filling the weave the difference in the wood covered and not covered by the rice paper seemed more noticable.
Here's a label I put on the kayak I made my daughter.
Good luck.
