Anyone have experience with wire inlay? I've never done it myself but seen videos of people doing it and plenty of pictures to want to do it on the boat I'm building right now. Any tips would be very much appreciated! Thanks
Most of the videos I've seen on wire inlay are showing solid wood being used. You might want to experiment with a scrap if you're going to use plywood because the finished surface layer is pretty thin. I'm also wondering how it would work with a boat which is exposed to the hot sun and the cold of winter versus a bowl or piece of furniture you normally see in the videos. Maybe you could inlay some plywood, epoxy then varnish it well and put it outside to see what happens.
RE: Wire inlay
» Submitted by wing15601 - Sat, 7/4/15 » 8:47 AM
