I'm going to use the flattening agent with Brightsides to produce a semi gloss look. Interlux says a 1;1 ratio and only need to flatten the top coat. Is this the experience of other builders. 2 coats PreKote and 2 coats paint for the interior. I have no other plan for this color paint. Should I just mix the entire can of flattenng agent and the whole can of paint and seal the remainder for future touch ups? Any experience is greater appreciated. Thanks Dan
RE: Interlux Flattening agent
Thanks Dick, I was hoping you would reply as I have read your posts about the skiff and knew you used the flattening agent. The brightwood will be a satin finish. I won't be doing that until the final stage and the painting is done. What is your thought about getting to a satin finish with the paint. Will a 1:1 be enough. I understand the trial technique but am too inpatient to wait for it to dry. thanks Dan
Dan,
1:1 will be plenty. You might want to use less. Patience is the most important virtue of a good boat builder.
Cheers!
» Submitted by DICKDOWDELL - Mon, 5/18/15 » 9:33 AM
Dan,
I used the Interlux flattening agent with Brightsides for the interior of my Peeler Skiff. I was looking for a pretty flat finish and mixed 1:1. Worked well and has been very durable so far.
I would recommend, if you don't expect to need the full can of paint, that you mix about an ounce of paint with a half ounce of flattening agent and try it on a smooth surface to see how it looks. If that provides the semi-gloss finish you want then you know the ratio you need. If it's not flat enough, go with the 1:1.
You definitely need the flattening agent only for the final coat.
Cheers,
Dick
