I have been paddling my kaholo for a little over a year, but after yesterday I had about a cup full of water spill out the breathing tube when I took the plug out after putting my board up on the car. It was windy and choppy. The bow submerged at almost every swell. I only paddled about a mile.
Any suggestions
dont worry about it?
redo the plug to get a better fit?
install a totally different type of breathing tube?
it was more water than I have ever had after a paddle, usually there is none. It was choppier and windier than normal for me though.
RE: Lots of water in my board
Good call on the handles. I hadn't thought about that. I am going to take a look at the handle and the plug tomorrow. Thanks for the input.
» Submitted by Tim Broyer - Thu, 6/5/14 » 8:46 AM
I also have been paddling mine for over a year. I would say that it is not normal. I've paddled through some stuff on the intercoastal that sounded similar and I've never seen or heard water inside my board. I suspect the edge of the plug is not seated fully or fudged up. A little marine silicone RTV around the base of the plug would probably do it. Also make sure your handles aren't allowing water in.
