In the manual for the lug rig it says that the hole for the mast to be 2 inches square. At another place besides the description of making that hole, it says 2,5 inches square. Since the mast is 57mm square, I think 2,5 is right. Has anybody seen this before?
RE: Mast partner ne dory
Frank,
Great info...I too am going to do leather on the mast partner, and plan to put leather on the mast step also (unless there's a reason not to). It would be great to see how you did your leather for the mast. Do you have an easy way to post a picture of the leather work you did for the mast?
Curt 830/997-8120
Thanks for info. I will wait until the boat is finished, and then complete the mast partner . Leather sounds fine, as it is traditional and can be made pretty. I`m building from plans and is making all the ekstra things before I start with the boat. I wonder what height on the mast is it surrounded by the mast partner?
2-1/2" is ideal and gives room for a bit of leather to cut down on wear at the partner. How the 2-inch measurement crept into the drawings I have no idea.
» Submitted by FrankF - Tue, 2/25/14 » 1:11 PM
I noticed that, so with the partner in place, I placed the mast in front of it and a bit off the floor, marked the point up the mast where it made contact, took the mast dimensions at that point, and cut the hole in the partner a bit large to allow for a leather buffer. I think it did come out to 2.5. Don't want too tight a fit or its hard to pull out after a sail. The leather helps.
