17' CLC Northeaster Dory and Trailer for sale in Central Texas
Note to potential buyers:
- You can post a public reply to this thread
- Or you can contact this member directly.
Submitted by Moonchaser - Fri, 10/7/22 » 1:18 AM
FOR SALE!!
Boat was at the Inks Lake Messabout this coming Saturday 10/8/2022
17’ Chesapeake Light Craft (CLC) Northeaster Dory
Built in spring 2014. Sailed Maine, ocean and lakes, Michigan, inland lakes and Lake Michigan, Washington State, inland lakes, Juan de Fuca and Puget Sound.
An ideal boat for just about any weather.
Copper stitch and glue built at a high level of craftsmanship.
If you still want to tinkder in epoxy and wodd working, there a few more mods I was considering but need to sell it.
Builder: Curt Dennis, Email: curt.dennis@msn.com
Designer: John Harris, CLC
Discounted for quick sell.,
The following features were added/options NOT part of original kit:
SAIL SYSTEMS:
Balanced Lug
Tanbark fabric
Two reef points with grommeted cringles
Lazy jack system with lazy jack halyard to cradle sail when lowered
RUNNING RIGGING:
Dual boom downhaul to adjust sail and boom fore and aft for higher pointing
All lines led aft to Harken turning blocks on mast partner.
Cheek block on top of mast for “fast drop” sail
CONSTRUCTION FEATURES:
Rope epoxyed into all leading edges for a lifetime of wear
Inner rail with 3” blocks to provide many tie-off locations
Bow eye extra reinforced for no-concern towing in big water
Bottom paint is Petit Vivid red
Hull is painted Hateras off white
Rails and all other wood is varnished bright
Floor is covered in SeaDek for easy kneeling
Four (4) eight foot spoon oars
Extra open oar locks to store when not in use
One set of plastic oar sleeves and matching oar lock, other set rubber
Floatition blocks under all seat epoxied and painted
KICK UP RUDDER:
Shock cord loaded to spring up if hit obstruction
Shock cord loaded to spring down
Rudder blade straight down on both front and aft to reduce “barn door” effect.
Center of pressure of new rudder further forward than stock rudder for easier control.
Cleat on starboard rail to hold tiller extension
Removable tiller for easier storage
https://photos.google.com/share/AF1QipNsZ4vFak0CMNGSUEBClfpC727S_h0XHeqMPlzghYIj6-mOSTU7whqkw6m10PZGXg?key=aHpKZy1pcmlTakVsLWpodnlvZnhEdlhjMDF0S1R3
DAGGERBOARD HOLDING METHOD:
Shock cord through handle and around mast to “wedge” in place at any height
Tape on rudder to indicate when daggerboard is protruding from bottom of boat
PROTECTION:
Waterproof cover with Sunbrella rope hem around cover
Indoor outdoor carpet covers for rudder, tiller, daggerbord,
Sunbrella sail bag for use with sail on boom
Sunbrella bags for all 4 oars.
TRAILER:
All aluminum
Spare tire
Leaf springs
Carpeted bunks
All lights work
Bearing buddies
RE: 17' CLC Northeaster Dory and Trailer for sale in Central Texas
Is this boat still for sale? Where is it located and what are you asking for it?
Sam
Sam
» Submitted by Moonchaser - Tue, 11/1/22 » 9:12 PM
17' CLC Northeaster Dory and Trailer for sale in Central Texas ver.2
FOR SALE!!
Will be in the Inks Lake Messabout this coming Saturday 10/8/2022
Located: betweeen Fredericksburg and Kerrville Texas, Feel free to send me an email for more info/
References available
Build web site:
https://photos.google.com/share/AF1QipNDEE1P1jmAocgYHZmUV_6tdnCZLqo_n3tPaK8c18j4Kg0UGdxrXHLxaYS5YkBaFw?key=aDgxQTdRRk95aFJjMGxCRzgyNm5LaS1sSDNKMFdR
Make an offer!!
SAIL SYSTEMS:
Balanced Lug
Tanbark fabric
RUNNING RIGGING:
Flotation under all seats, epoxied and painted building foam,
KICK UP RUDDER:
PROTECTION:
TRAILER:
All aluminum
Spare tire
Leaf springs
Carpeted bunks
All lights work
Bearing buddies
