Re: vcp hatches
Posted by Dave Houser on Jan 14, 2008
I used KajakSport hatches with a plywood shim-stack recess on a curved deck. The bottom of the recess was constructed flat to fit the base of the rim and the top of the shim stack was filed to match the radius of the under side of the deck. Be sure the top of the rim is slightly above the top of the deck to avoid the chance of leaks.
In Response to: vcp hatches by Alan O'Neill on Jan 13, 2008
- Re: vcp hatches by James E on Jan 14, 2008
- Re: vcp hatches by Alan O'Neill on Jan 14, 2008
Re: vcp hatches by Dave Houser on Jan 15, 2008
- Re: vcp hatches by Alan O'Neill on Jan 15, 2008
- Re: vcp hatches by Doug S on Jan 16, 2008
- Re: vcp hatches by James E on Jan 15, 2008
