Re: wavy chine lines
Posted by J. Schott on Nov 2, 2007
Did you bevel the edges of your panels where they join together? If you bevel the edges, the panels will be much easier to hold in alignment and give you a nice, fair joint line. Assuming that this is the case, and you have not glued it together yet. I would take it apart, bevel the edges, and reassemble. By not taking care of the cause of the problem, the panels will not be shaped properly. No amount of sanding will straighten a wavy hull panel. Here's a link to the shop tip that explains the process better than I can.
Shop Tips
In Response to: Re: wavy chine lines by Chris J. on Nov 2, 2007
- Re: wavy chine lines by J. Schott on Nov 3, 2007
