Rudder cable routing
Posted by Kevin on Jul 18, 2007
I am going to add a rudder to my 17 lt. I have the Seal Line kit. My one question is what route do the cables take after they leave the foot braces? Obviously they go through the rear bulkhead quite low and then? Do they go to the deck and then along the top of the boat? Also, what else do I need? Should I put in some rubber tubing or grommets of some sort to protect the wood? What do you recommend? Thanks for the help.
- Re: Rudder cable routing by Tim Clark on Jul 18, 2007
