Re: WOOD DYE TO COLOR EPO
Posted by Reed Conley on Nov 1, 2006
I believe you can mix powdered aniline dyes with epoxy. It works with lacquer and polyurethane. Some are made by Behlen or Mohawk. You could just dye the wood, but might look different on joints and glued spots.
Expert Advice Since 1957
In Response to: WOOD DYE TO COLOR EPOXY by GLENN on Nov 1, 2006
