Re: Weights: Fact or Fict
Posted by Darryl on Jul 13, 2006
I should add that I too use the squeegee to remove as much excess epoxy as possible but with a low lamp and after the epoxy "levels" itself, you will see wetter areas than others. If you don't no need to do anymore. If you do, hit these areas within 20 mins. And Yes, you may fill a trash can full of wet & heavy T.P.
In Response to: Re: Weights: Fact or Fict by Darryl on Jul 13, 2006
- Re: Weights: Fact or Fict by James on Jul 20, 2006
