Re: Epoxy not curing
Posted by Steve Miller on May 20, 2006
After 3 days of 80 in your tent the thicker drips are not cured. I would get out the scraper. Use a heat gun or hair dryer to speed the process. Epoxy softens at about 140 so go really easy if you use a heat gun. Heat and scrape until you can't get any more goo up. My experience is that the uncured goo will bubble pretty easily and be not all that hard to get off. If needed you can solvent wipe but�I would be inclined to sand a bit too. Good luck. Be sure to stir well next time. I tend to mix a min of 3 minutes on most batches. Tiny batches get at least 2 full minutes.
In Response to: Epoxy not curing by Tim on May 19, 2006
- Re: Epoxy not curing by M Davis on May 20, 2006
Re: Epoxy not curing by Laszlo on May 21, 2006
- Re: Epoxy not curing by Tim on May 22, 2006
- Re: Epoxy not curing by Willie on May 22, 2006
- Re: Epoxy not curing by Tim on May 23, 2006
