Re: Minor varnish issue
Posted by Darryl on Apr 29, 2006
Brett, I would toss the brush and start using the largest $1 foam brushes. I'm on my 5th coat and using no thinner (garage is 65) but moving fast to keep the wet edge. I wet sand with 400 grit between coats, clean with denatured alcohol, then a tack rag & lastly strain the varnish. A new roller, foam brush and tray every time. The roller gets it down fast.
In Response to: Minor varnish issue by Brett on Apr 29, 2006
