it will, easily
Posted by Charlie Jones on Apr 14, 2006
just cut the wire leaving plenty to grip with needle nose pliers. Heat the other end and pull as you are heating. In a second or two it'll just slide out, and when the eopxy cools it rehardens, with no lose of strength.
Same thing applies when you need to remove a screw that's epoxied in- just heat the head with a soldering iron and back it out.
In Response to: Re: eastport pram by mike noeske on Apr 14, 2006
- Re: it will, easily by larry Davidson on Apr 15, 2006
