Re: Epoxy finish.
Posted by Darryl on Mar 26, 2006
Kev, You may be looking at a contamination problem if you already put 3 coats of epoxy over the fiberglass with a roller & see orange peel. I would try sanding it and then cleaning the surface to see what it looks like afterwards before adding a heavy 4th coat of epoxy. No kersosene stove right?.
In Response to: Epoxy finish. by Kev Robinson on Mar 26, 2006
- Re: Epoxy finish. by Rich on Mar 27, 2006
Re: Epoxy finish. by Angie on Mar 29, 2006
- Re: Epoxy finish. by Rich on Mar 29, 2006
