Exhaust outside
Posted by Mike D on Oct 8, 2005
Just finished up an evening of deck sanding. Most with the ROS hooked to the shop vac with the exhaust ducted outside. Virtually no dust in the room or on the boat and the sanding discs (5 hole Porter Cable) don't load up.
In contrast sanding the shears with the hand sanding block was a whole different ball of wax. Epoxy dust everywhere and the paper loaded up really fast. I know it is a very bad idea to try to use the ROS on the shear edges. Oh yes, I also have know how to patch bare spots on the shears. :-)
Happy building, MD
In Response to: Re: ROS vs 1/4 sheet sand by don on Oct 8, 2005
