Sand after cleaning
Posted by Robert N Pruden on Jul 7, 2005
If you use the boat first, clean before sanding, then sand, then wipe it down using alcohol, then varnish. The alcohol wipe removes the dust from sanding without contaminating the surface with water.
Robert N Pruden
In Response to: Re: Use the boat. by Mislav on Jul 7, 2005
- Re: Sand after cleaning by John on Jul 7, 2005
