epoxy doesn't dry
Posted by LeeG on Jul 7, 2005
Is it soft, wet, ? If you didn't mix it well enough then one area could have an insufficient ratio of resin/hardener and it's taking longer to cure,,or not curing at all. If it's tack free (not sticky) then put a lamp on it to raise the temp up to 90 degrees and it should cure up in 24hrs. A thicker coating of epoxy doesn't take longer to CURE like a thick coating of paint that takes longer to DRY.
In Response to: HELP! by Pete on Jul 6, 2005
- Re: epoxy doesn't dry by Pete on Jul 7, 2005
Re: epoxy doesn't dry by RogerJ on Jul 7, 2005
- Re: epoxy doesn't dry by Toby on Jul 7, 2005
- Re: epoxy doesn't dry by LeeG on Jul 7, 2005
- Re: epoxy doesn't dry by Chris on Jul 7, 2005
- If parts have cured, and by CharlieJones on Jul 7, 2005
- Re: If parts have cured, by Pete on Jul 7, 2005
- IT WORKED!!!!!! by Pete on Jul 8, 2005
- Re: IT WORKED!!!!!! by Gober on Jul 8, 2005
- Re: If parts have cured, by Steve Miller on Jul 8, 2005
- Re: REUSE OF CONTAINERS by RogerJ on Jul 8, 2005
- Re: REUSE OF CONTAINERS by Pete on Jul 8, 2005
