Re: varnish times
Posted by Steve Miller on Jul 6, 2005
I would worry more about soft varnish than soft epoxy at this point. I like a week for paint and varnish to harden but for your trip I'd second coat the hull and do 2 fast coats on the deck - no sanding in between other than a 3M pad and get a good 5 day cure. Do the deck coats first and get the boat out in the sun for a few days (after the varnish is 24 hours old) if you can. You are going to sand it anyway after you get home so neatness does not really count now.
In Response to: Re: varnish times by Jon T on Jul 6, 2005
