Re: Like Grandma
Posted by Kyle T on Jun 3, 2005
How thick were the original strips. I built an entire boat out of 3/16 thick strips and planed a lot of that off. Some strip builders start out with 1/8 thick strips and then sand them down some. If you are leaving at least an 1/8 of thickness then you should be safe enough giving that you should be glassing the inside and out of the deck.
--KT--
In Response to: Like Grandma by RogerJ on Jun 3, 2005
