Old Kit?
Posted by Howard on Jun 2, 2005
Kemp,
saw your pictures...and was wondering if you were building from one of the older kits...(the deckbeam looks like the old style that they stopped using in 2002/2003.
anyway, the reason for writing is that since that time CLC started adding some additional reinforcements around the hatch openings...that are highly recommended. when i refinished an older boat last year, i got CLC to ship me a set of the upgraded hatch reinforcements and upgraded the hatches when i redid the boat.
anyway...since you are still in construction.. wanted to give you a heads up while it is still easy to add (only takes about an hours time) but significantly reinforces the hatch openings.
otherwise..looks like you are doing a great job...best of luck
hs
In Response to: Last epoxy coat by Kemp on Jun 2, 2005
- Re: Old Kit? by Kemp on Jun 3, 2005
- Re: Old Kit? by Howard on Jun 3, 2005
