Ground Fillet Images
Posted by raul calzadilla on May 30, 2005
The first three pictures at Village Photo are the result of Right Angle Grinder (4"). Next grinding session I will try grits: 90, 80, 60 to find a less agressive (forgiving) removal of epoxy.
Should I go back re-apply 3" tape? I believe this MillCreek 16.5 does not require fiberglassing of the interior. Just 3 coats of epoxy.
In Response to: you're brave by LeeG on May 30, 2005
- Images by raul calzadilla on May 30, 2005
