Ice bags
Posted by Robert N Pruden on May 11, 2005
I did my end pours when all else was done in a similar fashion, Lloyd. The trick here is to do it in small batches to avoid excessive heat build-up. When I did get a heat build-up, I wrapped the end in question with a plastic bag of ice. That solution worked well.
Robert N Pruden
In Response to: I did it last by Lloyd Peterson on May 11, 2005
- Ice is cheap in Alberta by Lloyd Peterson on May 11, 2005
