Re: assembling the hull
Posted by Matty C on May 4, 2005
thank you for your help, things are going smoothly. The fact that i am building in an attic is not a problem because it has a very large door from which i can lower it (like a barn). Only problem that i have run into is the book said to drill 1/4 inch into it and then there was some misprint which looks like an 8 or a B, i think it was supposed to be 1/2 because I have to redrill all of the holes since the rabbets go in more than 1/4. Should i fill the bad holes in or will it be fine with the epoxy and fiberglass, etc Thanks again
In Response to: Re: assembling the hull by CLC on May 3, 2005
