Re: Thanks Guys!
Posted by CLC on Mar 16, 2005
>>>>So, I figure a few days in the sun to REALLY cure the epoxy prior to final 320 sanding and varnishing won't hurt?
A few days of sun won't do lasting harm, but make sure there isn't any thing resting on the surface of the boat that would shadow the hull. Say, if you left a piece of webbing draped across the deck, after just a day or two in the sun you'd have a colored stripe where the wood and epoxy had "aged" differently. Over the years we've often tested boats in the epoxy-only stage, and I've been dismayed to find stains where the boats had sat atop a car with tie-down straps across the decks.
In Response to: Re: Thank's Guys! by Mac on Mar 16, 2005
- Re: Thanks Guys! by Mac on Mar 16, 2005
